It is currently Sun Jul 20, 2025 4:42 pm
PostPosted: Sat Nov 09, 2013 6:32 pm
Does anyone have a exploded diagram of a late rover mini brake master cylinder and brake booster? My master cylinder is the green tag type.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Nov 09, 2013 7:38 pm
when you order a rebuild kit it should come with one....when we ordered one for my dad it did any ways
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat Nov 09, 2013 8:16 pm
That's what I thought too carter. But the was nothing in the kit. I will email the supplier, thanks
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Nov 09, 2013 8:20 pm
oh ok what yr model is your rover? if its the same as my dads ill see if we still have it and ill try n scan it up for you
1970 mini k
1975 leyland
PostPosted: Sat Nov 09, 2013 8:28 pm
I only have the brake master cylinder/servo and pedal box assembly which I'm fitting to an earlier car. It's got a green tag on the master cylinder which according to minispares makes it 1988-1995.
It would be great if you have and could load the diagram.
Your manual doesn't have a diagram for the bias valve to by any chance does it?
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Nov 09, 2013 8:37 pm
there were two brake booster/master cylinders for the rovers i think and unfortunately my dads is the later one a 99 model..... so i dont think this is any help to you is it?.,......its one with two pistons in it one pushes back brakes one pushes front .....not sure if the older one does the same
1970 mini k
1975 leyland
PostPosted: Sat Nov 09, 2013 9:11 pm
the difference is if the internals are held by a metal circlip or a plastic retainer. the plastic retainer hit the market around 1995, but the one with the metal circlip can be found in later cars.
in general they are the same since end of 1988 with the boosted front-rear split system.
Rover 214 atm ....
PostPosted: Sun Nov 10, 2013 9:48 am
Thanks Klas and Carter I've found someone on eBay selling factory manuals for 1996-2000 minis and will refund if the information I want isn't in there.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
Users browsing this forum: Bing [Bot] and 89 guests
