It is currently Sun Jul 20, 2025 4:48 am
PostPosted: Tue Nov 19, 2013 4:06 pm
There are nyloc nuts on the swivel joints that attach to the steering arms on the hubs - when you screw down and start to engage the nylon lock bit the spindle turns - how do you hold it to do it up?
David L
PostPosted: Tue Nov 19, 2013 4:08 pm
Use a jack to apply a little pressure underneath the steering arm ball joint. This will lock the taper in enough to do the nut up.
PostPosted: Tue Nov 19, 2013 6:44 pm
Or just lever it up with a bar :)
Dalmeny
