Clubman ID please https://www.ausmini.com/forums/viewtopic.php?f=2&t=83546 |
Author: | Minifreak_brg67 [ Tue Nov 19, 2013 6:20 am ] |
Post subject: | Clubman ID please |
I have a friend that has acquired a clubby but at this stage the compliance plate is missing the body number is 022D22sm101259 Any info would be great I think it is a Leyland Mini S |
Author: | John Sneddon [ Tue Nov 19, 2013 8:15 am ] |
Post subject: | Re: Clubman ID please |
Can I get you to check the number please as what you have stated is incorrect. The number should take the form 021 which is Mini or 022 which is Mini S D which is Mini Sedan manual transmission. If the vehicle was produced between January 1973 and March 1974 then this letter would be A 2S which is 2 door Saloon 1 or 2 which is trim level M09 or M10 which is engine size of 998 or 1098cc and then the serial number. There should be a build date on the build plate as well. |
Author: | mitchcairns [ Tue Nov 19, 2013 8:28 am ] |
John Sneddon wrote: Can I get you to check the number please as what you have stated is incorrect. The number should take the form 021 which is Mini or 022 which is Mini S D which is Mini Sedan manual transmission. If the vehicle was produced between January 1973 and March 1974 then this letter would be A 2S which is 2 door Saloon 1 or 2 which is trim level M09 or M10 which is engine size of 998 or 1098cc and then the serial number. There should be a build date on the build plate as well. Great info John! I just bought a clubman too and was also wondering about the numbers.. The guy I bought it off said it was a 998, but maybe it's not.. Mine is 021D2S2M10 8543 |
Author: | John Sneddon [ Tue Nov 19, 2013 4:16 pm ] |
M10 the build plate indicates a 1098cc engine however the true test comes from the code on the engine. If it is 10??? then it is 1098cc however if it is 99H??? then it is definately 998cc. |
Author: | mitchcairns [ Tue Nov 19, 2013 5:00 pm ] |
The engine is 10153747 |
Author: | drmini in aust [ Tue Nov 19, 2013 6:05 pm ] |
John Sneddon wrote: M10 the build plate indicates a 1098cc engine however the true test comes from the code on the engine. If it is 10??? then it is 1098cc however if it is 99H??? then it is definately 998cc. Means it was built as a 998, but... Many 998 (eg. 99H) motors got a 1098 crank & pistons put in when rebuilt over the years, it's an easy way to get 10HP and 8ft/lb of torque for nothing. ![]() [edit] for clarity |
Author: | John Sneddon [ Thu Nov 21, 2013 7:11 pm ] |
1015 is definitely a 1098cc engine |
Author: | mitchcairns [ Thu Nov 21, 2013 7:57 pm ] |
Thanks John!! |
