How do you tighten the steering rack swivel joint?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=83553
Author:  Wombat [ Tue Nov 19, 2013 4:06 pm ]
Post subject:  How do you tighten the steering rack swivel joint?
There are nyloc nuts on the swivel joints that attach to the steering arms on the hubs - when you screw down and start to engage the nylon lock bit the spindle turns - how do you hold it to do it up?
Author:  Mick [ Tue Nov 19, 2013 4:08 pm ]
Post subject:  Re: How do you tighten the steering rack swivel joint?
Use a jack to apply a little pressure underneath the steering arm ball joint. This will lock the taper in enough to do the nut up.
Author:  dalmeny [ Tue Nov 19, 2013 6:44 pm ]
Or just lever it up with a bar :)
