Any ideas before I pull it apart https://www.ausmini.com/forums/viewtopic.php?f=2&t=83562 |
Author: | Wombat [ Wed Nov 20, 2013 2:14 pm ] |
Post subject: | Any ideas before I pull it apart |
While fitting the disc brake assembly to the passenger side the drive shaft came out of the diff end joint. I shoved it back in and it appeared to be all sweet apart from getting the boot clips back on. Mucking about with the rims and tyres the other day I discovered the wheel won't rotate for more than about 1/8 turn forward or backward - car is not in gear and the other side rotates OK. What could have happened and how do I tackle it? |
Author: | Harley [ Wed Nov 20, 2013 2:18 pm ] |
Post subject: | Re: Any ideas before I pull it apart |
Has a circlip possibly gotten into a ballrace and locked it maybe? |
Author: | drmini in aust [ Wed Nov 20, 2013 3:12 pm ] |
Does it turn with the wheel off? |
Author: | Wombat [ Wed Nov 20, 2013 3:13 pm ] |
drmini in aust wrote: Does it turn with the wheel off? No |
Author: | drmini in aust [ Wed Nov 20, 2013 3:26 pm ] |
Take the boot off the pot joint that side and verify all the balls are back in the slots properly. |
Author: | Wombat [ Wed Nov 20, 2013 3:58 pm ] |
Sounds like a plan - thanks |
Author: | drjbeam [ Wed Nov 20, 2013 5:36 pm ] |
I got grease coming out of mine there less then 6 months old |
