Innocenti Mini 850 only running on 2 cylinders https://www.ausmini.com/forums/viewtopic.php?f=2&t=83677 |
Author: | robbyasti [ Thu Nov 28, 2013 6:55 pm ] |
Post subject: | Innocenti Mini 850 only running on 2 cylinders |
I have recently bought an Innocenti Mini 850 which wasn't running. I have now managed to get it started but it only runs on 2 cylinders (1 and 2). There is a spark at all 4 plugs. I removed all 4 plugs and 1 and 2 were dry and sooty but 3 and 4 were wet with fuel. Obviously there is fuel and a spark going to all 4 cylinders but only burning at 1 and 2. I am thinking it could be a faulty head gasket. At the moment I don't have a compression tester to confirm this. The dizzy has not been touched. The plugs are all new. The points gap is correct. The spark is strong on all 4 cylinders. Is there something that I am missing, could it be a problem with the timing? Thanks |
Author: | peterb [ Thu Nov 28, 2013 7:58 pm ] |
Post subject: | Re: Innocenti Mini 850 only running on 2 cylinders |
Do a compressions check, that all that's left. If it runs it muss have fuel, you've confermed spark, so compressions all that's left. Has it sat a long time, stuck valve (s)?? |
Author: | Mick [ Thu Nov 28, 2013 8:05 pm ] |
I have been caught so many times with the spark plug sequence...any chance? 1-3-4-2? |
Author: | robbyasti [ Thu Nov 28, 2013 9:09 pm ] |
It has been stood for 8 years but the previous owner claims that it was running perfectly 3 months ago. Considering that the cluch pedal is rock solid and there is no pedal on the brakes, I am starting the think that it is actually 8 years since it was last running and being used. The plug leads are in the correct order. I will do a compression test. Thanks for the replies. Rob |
Author: | bnicho [ Fri Nov 29, 2013 10:31 am ] |
Mick wrote: I have been caught so many times with the spark plug sequence...any chance? 1-3-4-2? Watto got that wrong three times during Shitbox Rally and the trip home. ![]() |
Author: | Thorlek [ Fri Nov 29, 2013 6:58 pm ] |
robbyasti wrote: the previous owner claims that it was running perfectly 3 months ago It probably was running perfectly 3 months ago..... on 2 cylinders! Unless I know the person, I generally assume anyone trying to sell me something is bullshitting me, that way I'm never disappointed when it turns out they were actually bullshitting me |
Author: | Mick [ Fri Nov 29, 2013 7:11 pm ] |
Thorlek wrote: robbyasti wrote: the previous owner claims that it was running perfectly 3 months ago It probably was running perfectly 3 months ago..... on 2 cylinders! Unless I know the person, I generally assume anyone trying to sell me something is bullshitting me, that way I'm never disappointed when it turns out they were actually bullshitting me Wanna buy some Cooper S wheelnuts? |
Author: | Thorlek [ Fri Nov 29, 2013 7:14 pm ] |
Mick wrote: Thorlek wrote: robbyasti wrote: the previous owner claims that it was running perfectly 3 months ago It probably was running perfectly 3 months ago..... on 2 cylinders! Unless I know the person, I generally assume anyone trying to sell me something is bullshitting me, that way I'm never disappointed when it turns out they were actually bullshitting me Wanna buy some Cooper S wheelnuts? 3 per wheel, are you sure this is a full set? |
Author: | robbyasti [ Fri Nov 29, 2013 7:18 pm ] |
Thorlek wrote: robbyasti wrote: the previous owner claims that it was running perfectly 3 months ago It probably was running perfectly 3 months ago..... on 2 cylinders! Unless I know the person, I generally assume anyone trying to sell me something is bullshitting me, that way I'm never disappointed when it turns out they were actually bullshitting me Very true! I knocked off €500 of the asking price because I expected to find a few problems. I have now found a valve seized. |
