Definitely, the expansion tank is the key. It won't prevent overheating by itself, but indirectly it stops your mini losing water, and returns it to the radiator as the temperature cycle goes down again once you start moving. My expansion tank (a brass Morris 1100 unit) is mounted up under the passenger arch. My last three minis have had one up under there without a fault. Rocks don't bother the brass tanks.
http://i6.photobucket.com/albums/y223/A ... C04042.jpgChecking coolant becomes a once every season check.
Along with a 93 degree thermostat, you can get an 83 degree thermostat, and a 73 as well.
