It is currently Sat Aug 16, 2025 11:20 am
PostPosted: Tue Dec 03, 2013 10:20 am
I've mentioned this in my other thread, but I'm lead to believe I can purchase an adaptor to convert my swinging needle in my 1.5" SU to the non-swinging needle type.
Does anyone know where I can buy these?
mick
PostPosted: Tue Dec 03, 2013 10:30 am
Belay my last,
SU Midel have them, 11 bucks each...
PostPosted: Tue Dec 03, 2013 8:38 pm
I did this on some 1 & 3/4 SU's.
Swapped over the pistons which did work for me.
But, I did find that the "jet bearing" was different. This being the tube the jet fits into.
The fixed needle ones can be moved around to centralise the jet.
The floating needle ones were different, not allowing for this adjustment.
Not sure if the 1.5's are the same.
PostPosted: Tue Dec 03, 2013 8:48 pm
Yes, and thanks for mentioning it.
I was able to pick up a pair of fixed needle jet bearings from Minispares. They were about 10 dollars each and replaced the entire lower jet support assembly.
PostPosted: Wed Dec 04, 2013 6:40 am
Hi Guys,
Do you know if there is a conversion for the spring swing needle in a HIF to a fixed mounting using the current needle?
Thanks
Grant
100% Pure A Series Turbo
PostPosted: Wed Dec 04, 2013 7:03 am
The adaptor for the needle is the same as far as I know.
PostPosted: Wed Dec 04, 2013 6:02 pm
Mick , is all this because you have made a set of twins out of two single 1-1/2" carbies ?
PostPosted: Wed Dec 04, 2013 6:04 pm
No, I have a pair of opposite bowl, waxstat, flexible needle 1.5" SUs. The buggerising around is because I don't wish to deal with the waxstat and flexible needle if I can get away with it.
The adaptors came in the mail today, I'll get an image and some dimensions up later on to answer the question above.
PostPosted: Wed Dec 04, 2013 6:35 pm
Yeah Mick , untill the other day in your other post , i'd never heard of Waxstat needles , so i'm curious .
I ended up with an 1-1/2 carby off a motor i bought and whilst cleaning it up i noticed it had a needle that was flexable , ( i'd never seen one before ) , the motor it came off was a Morris 1300 Auto .
PostPosted: Wed Dec 04, 2013 7:56 pm
I've not dealt with them, but have heard enough of to figure I don't want to. Its too crowded underneath the mini manifold as it is, I don't want to frig around with them once they're in other than to tune them and forget....
The inserts directly replace the original inserts, and a standard solid needle takes the place of the swinging needle assembly.
PostPosted: Wed Dec 04, 2013 9:44 pm
I've inserted the brass inserts into the SU piston until flush. The centers needed a little bit of a massage as the needle couldn't be pressed in past the cross drilling.
The needles once inserted were centered in the jet by setting the pistons up with the jet enrichment nut and spring removed, and the jet adjusted until the dropping piston makes a nice sweet 'click'. The new jet linkages to convert from waxstat to standard jet are in place and hooked up and it all works smoothly.
I reassembled it all, and now they're done. The float bowl is what is pending now.
PostPosted: Thu Dec 05, 2013 9:27 am
Boostedmini wrote:
Hi Guys,
Thanks
Grant
You can 'convert' a swinging needle to fixed just by pulling off the little hat and deburring the crosshatch on the end of it.
All I did was put the needle in a small vice just with the edges of the hat sitting on the top of the vice, and gently tap the needle through, then running the crosshatched bit in the wire brush on the bench grinder.
PostPosted: Thu Dec 05, 2013 10:46 am
simon k wrote:
Boostedmini wrote:
Hi Guys,
Thanks
Grant
thanks simon,
i think i follow the the "top hat" taps off the needle and you then fit the needlt to the brass bush Mick has displayed and then that fits in the hole of the piston?
PostPosted: Thu Dec 05, 2013 11:06 am
Boostedmini wrote:
simon k wrote:
Boostedmini wrote:
Hi Guys,
Thanks
Grant
thanks simon,
Users browsing this forum: No registered users and 70 guests
