Slow and dim
https://www.ausmini.com/forums/viewtopic.php?f=2&t=83775
Author:  Robmitch916 [ Fri Dec 06, 2013 7:57 pm ]
Post subject:  Slow and dim
The subject isn't a description of me by the way. Quick one for you tech experts. I got my indecators to work but the left side ones are dim and slow when coming on I have the correct bulb in
Any ideas?
Rob M
Author:  MiniBill [ Fri Dec 06, 2013 8:05 pm ]
Post subject:  Re: Slow and dim
Bad earth perhaps ?
Author:  carter [ Fri Dec 06, 2013 8:10 pm ]
Are both indicator bulbs working when you put your indicators on?
Author:  andrew9 [ Fri Dec 06, 2013 8:12 pm ]
I had a heap of trouble with my indicators just this week, they were slow, and my stalk light wouldn't work.
Cleaning the fuse box with some contact cleaner, and replacing the flasher can with a $7 generic three pin one fixed them right up.
If it's only one side and all the bulb wattages are the same I'd say it must be a dirty connection or a bad earthing point. I'd try fiddling with the nuts on the back of the tail light on the side that is slow first, the rear indicator earth is through them. I don't know where the front indicator earth goes, it's a wire into the loom
Author:  Robmitch916 [ Sat Dec 07, 2013 5:02 pm ]
Cheers guys I will check the earthing and let you know how it goes
Author:  peterb [ Sat Dec 07, 2013 5:08 pm ]
The front ones do have earth wire but also earth through mounting screws.
