Help with Brass oil galley plugs- engine block https://www.ausmini.com/forums/viewtopic.php?f=2&t=83779 |
Author: | AEG163job [ Fri Dec 06, 2013 9:17 pm ] |
Post subject: | Help with Brass oil galley plugs- engine block |
It's now 20 years since I last removed & replaced these. As Vizard recommends, removal to clean the oil galleries properly, is necessary. Does anyone know where these can be obtained? Any advice appreciated. |
Author: | 1071 S [ Fri Dec 06, 2013 9:22 pm ] |
Post subject: | Re: Help with Brass oil galley plugs- engine block |
Berco supplied my screw in plugs - but it was a while ago... Cheers, Ian |
Author: | drmini in aust [ Fri Dec 06, 2013 9:26 pm ] |
I used to buy brass welch plugs years ago, but lately all I have found available for Minis are steel ones. Originals were steel and they lasted pretty well, so using brass was probably overkill. ![]() [edit] I buy them from Karcraft. edit 2 My bad I thought you meant the water jacket.. ![]() re the oil ones I machine new brass ones, .504" dia and drive them in. |
Author: | mini_mad_matt [ Fri Dec 06, 2013 9:50 pm ] |
I tap a thread and make bungs out of bolts to screw in. 9/16th UNF is the size i use i believe. Just a bit of a job to have the bung screw in far enough but not too far and in some cases not protrude from the block. |
Author: | AEG163job [ Sat Dec 07, 2013 10:44 am ] |
Many thanks for all the replies. ![]() |
Author: | John Smidt [ Sun Dec 08, 2013 1:31 pm ] |
AEG163job wrote: It's now 20 years since I last removed & replaced these. As Vizard recommends, removal to clean the oil galleries properly, is necessary. Does anyone know where these can be obtained? Any advice appreciated. I have them in stock if that is any use to You 02 45776221 they are genuine parts but made a little different to what where before. Regards John |
Author: | AEG163job [ Sun Dec 08, 2013 9:36 pm ] |
Excellent John, call call you 2morrow. P. |
