Kurross wrote:
Interesting topic, I just had my mechanic out to do a blueslip and we struggled to find the "body/chassis number". After some searching and a bit of googling we sanded back the paint on radiator shroud and found a number stamped. We used this for chassis number, even though didn't match bmc ID tag, should there be another one behind master cylinders? Not real keen to pull them out to be able to sand back to find another number....
I don't understand these blueslippers "googling" for answers. They have a technical section of the RTA with all the records from the carmakers like BMC explaining the location of these numbers. Thats who they are suppose to contact.
The location of the number used for rego on a mini depends on the year. As stated BMC changed it a few times.
By behind the master cyld I meant just below the firewall ID plate. Like below this is just behing the MC's on the firewall. often a bit rusty cause they stamped into the paint. You may not see it because it has been covered in layers of paint or it's not there for your model.
courtesy BMC experience
