It is currently Thu Jul 31, 2025 3:34 pm
 Post subject: how to advance timing?
PostPosted: Fri Jun 24, 2005 1:58 pm
I'm having a blonde day here - to adavnce timing, I rotate dizzy anti-clockwise - correct?
PostPosted: Fri Jun 24, 2005 2:23 pm
As far as I remeber clockwise it is...
Generally the revs will increase the more you advance the timing from standard, are you setting your timing using a timing light if so you should be able to see the numbers on the fly wheel.
Roads need more corners
PostPosted: Fri Jun 24, 2005 10:16 pm
I just put a bloody big (reasonable size) spotch of paint on the timing mark
works for me
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Fri Jun 24, 2005 10:27 pm
you will have to find out the direction your rotor button turns to definitely find out which way is advancing
but
in Herman and Trev (my only a series models)
turning the dissy body clockwise advances it
Inconspicuously Conspicuous
PostPosted: Fri Jun 24, 2005 10:37 pm
Advance your Clock :wink:
PostPosted: Sat Jun 25, 2005 9:50 am
Cheers guys I new I had a 50-50 chance. Don't have a timing light, so doing some seat of the pants tuning...
PostPosted: Sat Jun 25, 2005 9:52 am
if youre game
loosen the clamp bolt,
turn on car
and turn it either way
retarding will sound like its slower
advancing will cause it to pick up its revs
retarding too much
and advancing too much
will cause it to slow as well. you will have to find a nice balance
PostPosted: Sat Jun 25, 2005 9:57 am
Yep I originally thought it was clockwise, so advanced it, but must have been too far as it had no power, and wouldn't rev over 3,000. Didn't ping tho, so I thought I had retarded it.
Mental note - baby steps...
Users browsing this forum: Bing [Bot] and 94 guests
