It is currently Wed Aug 13, 2025 8:59 pm
PostPosted: Mon Dec 02, 2013 4:53 pm
So i have a Mini Clubman and im currently trying to get a roadworthy.
One of the things on the list is that i have a worn steering rack.
What would be the best way to go about fixing it?
Hopefully its not to replace the whole thing cause that would be a pain in the butt!
Thanks!
1977 Clubby!
PostPosted: Mon Dec 02, 2013 5:00 pm
You need to have it checked out. There are four ball joints to check being the track rod ends on the steering arms, and the inner ball joints where the track rods connect to the inner rack. These can be checked with the rack in the car, but anything more than this is a steering rack out job, which means dropping the rear of the sub frame to get some access.
If you pull back the rubber gaiters on the inner ends, and have a busty assistant rock the steering wheel back and forth, you should be able to see where the movement is coming from. Do this both sides, having the wheels placed firmly onto something solid while it is also jacked up off the ground (like on ramps). Doing this can help show the problem more.
PostPosted: Mon Dec 02, 2013 8:12 pm
Thanks!
What would be the best way to go about fixing it? Put it at the very top of your list of things to do...find an expert.
Hopefully its not to replace the whole thing cause that would be a pain in the butt! Not replacing it might be any even bigger pain the butt and elsewhere on your body :roll:
PostPosted: Mon Dec 02, 2013 9:27 pm
Mick wrote:
If you pull back the rubber gaiters on the inner ends, and have a busty assistant rock the steering wheel back and forth, you should be able to see where the movement is coming from. .
If you have succes and use a busty assistant , could you post some pics of her rocking back forth?!
The formula for the length of a piece of string is simple: Twice as long as from one end to the centre!
PostPosted: Tue Dec 03, 2013 12:27 pm
the busty assistant would be me hahahaha!
there seems to be movement up and down past the ball joint
oh man this is looking to be the biggest pain in the butt. i have to decide whether i want to do it myself or get someone to do it!
1977 Clubby!
PostPosted: Tue Dec 03, 2013 3:30 pm
Hey Hulk
I has same problem with my clubby
Got a good local garage to do it. What it cost me in money it saved me in time and swearing
Job done
Got new brakes fitted at same time
Rob m
Black is the new Black
PostPosted: Tue Dec 03, 2013 5:09 pm
Robmitch916 wrote:
Hey Hulk
Job done
Rob m
hey rob!
how much did it cost you roughly? so i can call a few places and get some quotes, i dont wanna get ripped off cause im a girl. it happens way too often for my liking! hahaha
ALSO! are there any temporary fixes to stop the clunking so i can get a roadworthy?
1977 Clubby!
PostPosted: Tue Dec 03, 2013 5:50 pm
Ms. Hulk (Jesmine),
If I were in your position I'd call a few of the Mini businesses to get their thoughts and a quote. They will have the knowledge and parts to do the job the quickest and best way.
viewtopic.php?f=41&t=83593
I see you are in Melbourne. Personally I've used Link Automotive in Mitcham to prepare my car for a roadworthy, but there may be others closer to where you live.
PostPosted: Tue Dec 03, 2013 7:27 pm
Jasmine
That's the best advice. I pick mine up on Monday so I will let you know
PostPosted: Tue Dec 03, 2013 9:30 pm
Ummmmm Jazz....maybe I didn't make myself clear :?:
This problem is critical to the safety of the car and YOU :!:
Please stop wondering and get it to an expert Mini repairer ASAP :D
PostPosted: Wed Dec 04, 2013 12:40 am
The posting of her problem, and the seeking of advice clearly shows Jasmine is quite aware of the situation and its urgency. For that she deserves great credit.
Knowlegable suggestions have been offered - certainly more useful than a sanctimonious lecture :| .
PostPosted: Wed Dec 04, 2013 6:10 am
Trust me im quite aware of the urgency of this thats why i was asking for advice in the first place!
I'll be calling a few places today to get some quotes and see how i go! :)
1977 Clubby!
PostPosted: Wed Dec 04, 2013 10:06 am
Jesmine (I hope that's the correct spelling, as per your introduction post?),
The key piece of advice from those who know the Mini well is that there are a few things that need to be done correctly when working on a Mini steering rack that may not be obvious to a non-Mini mechanic. The replacement parts used, the sequence of assembly and the tightening of the U-bolts that hold the rack in position are all critical to avoid strain on the steering components and possible failure. That's why it's been suggested you use someone who knows what they are doing and has done it before, and not necessarily what's most convenient, like your local garage. From what you've said I'm guessing you know all this, but I thought it worth reinforcing.
Everyone on here has your personal safety at heart. :)
PostPosted: Wed Dec 04, 2013 10:15 am
sanctimonious?? oil look it up :roll:
PostPosted: Wed Dec 04, 2013 10:16 am
Good to hear :D
No one here wants to see any Mini or Mini driver damaged :!:
Users browsing this forum: Phil 850 and 256 guests
