It is currently Thu Aug 21, 2025 2:27 pm
PostPosted: Sun Dec 15, 2013 6:06 pm
Fitting new rear drums over new linings and won't go even when adjuster is fully backed off. What's the best way to go?
PostPosted: Sun Dec 15, 2013 6:34 pm
Do you have the shoes centred? You may need to gently take the sharp edges off the shoes or the ridge off the drums to coax them on.
PostPosted: Sun Dec 15, 2013 7:25 pm
The drum gets about halfway on the jams tight
PostPosted: Sun Dec 15, 2013 8:04 pm
Check the width of the shoes.
1-1/4" = rears. 1-1/2" = fronts. Fronts do not fit on the back, they behave as you described. :mrgreen:
Don't ask how I know... :oops:
[edit] use new shoes from Kc, they stop better than the rebonded cardboard ones brake shops sell here.
Last edited by drmini in aust on Sun Dec 15, 2013 8:11 pm, edited 1 time in total.
PostPosted: Sun Dec 15, 2013 8:07 pm
See if the new drums are binding on the hub without the linings fitted. Minifins that I have bought have this problem.
PostPosted: Sun Dec 15, 2013 10:07 pm
Shoes are 31mm so 1 1/4" - I have the old original shoes that came with the car I'll put them on and see if I can get them to work - thickness of pad and shoe is 6.5 -6.7mm on the old and 9.4mm on the new. The old drums fitted OK over the new shoes.- bit more meat in the new drum I guess.
PostPosted: Mon Dec 16, 2013 8:25 am
sounds like you have oversize shoes to me
PostPosted: Mon Dec 16, 2013 3:01 pm
Could be Matt -recall now that Glen Carpenter sold me some second hand drums and I could not adjust the the shoes tight enough - he than sold me some new shoes "on exchange" for the old ones but I never got around to dropping them off. Looking at the old shoes the pads are 4.3mm thick and the big black book says minimum pad thickness is 1.7 mm so I'll put them back in and keep the thicker pads with the old drums for another time or sale.
PostPosted: Mon Dec 16, 2013 4:06 pm
It is/was common out here for brake shops to skim the worn drums out to +1/32" or +1/16" and supply oversizes bonded shoes, radius ground to suit.
These will NOT then fit in a standard 7" drum.
Go buy some new shoes, they are cheap from Kc and elsewhere.
PostPosted: Tue Dec 17, 2013 12:29 pm
Thanks Matt and Doc for the heads up - will order end of the week when the credit card has recovered from the pre Christmas onslaught
Users browsing this forum: No registered users and 281 guests
