It is currently Sun Jul 27, 2025 3:56 am
PostPosted: Sun Jan 05, 2014 8:31 am
I currently have a 1275 with twin 1-1/4 su's. My question is would a single 1-3/4 do the same or better job?
I have a mate who is in to datsons and he thinks his got a couple of 1-3/4 up the back of the shed that he'll never use, he uses webbers.
On the plus side one su is easier to tune then two....
PostPosted: Sun Jan 05, 2014 9:34 am
The A series book by David Vizard says that the induction pulsing of these engines is such that only one cylinder draws on the single carb at a time, so it doesn't make much difference if there is one or two.
So then you can say that a single 1 3/4 would flow better that twin 1 1/4, assuming the manifolds and air filters are similar.
That's my interpretation anyway
PostPosted: Sun Jan 05, 2014 8:46 pm
Makes sense to me too, thanks for the reply
PostPosted: Mon Jan 06, 2014 7:36 am
I have seen a good road S motor give 90+HP (at the crank) on GR's engine dyno with twin HS2s, if you want more than this IMO you need either a pair of HS4s, a single HS6 or HIF44, or a Weber/Dellorto.
My2c,... :wink:
PostPosted: Mon Jan 06, 2014 5:43 pm
the MG lads answer this question often.
cross section of the twin hs2s is tiny tiny tiny bit more than HS6, so essentially the same, however flow wise hif44 beats hs6 by a little.
i would think it would come down to the flow on the manifolds.
PostPosted: Mon Jan 06, 2014 6:09 pm
Thanks guys the answers were similar to wgat i was thinking. I need to rebuild my twins so I thought I'd explore the opitions and the 1-3/4 just come up. I am trying to stay away from the weber until its on the road.
Users browsing this forum: JM1275 and 85 guests
