It is currently Wed Jul 30, 2025 7:19 pm
 Post subject: Third Gear
PostPosted: Thu Jun 23, 2005 9:22 pm
Here's an interesting one. Remote gearbox. Cannot get from second to third gear, but no trouble going from fourth to third.
Solution?
Reverse detent plunger rod worn. Worn rod turns and locks out third gear when changing in one direction, but ok when going back the other way. Replaced the detent rod, and all is fine.
PostPosted: Thu Jun 23, 2005 10:00 pm
Good to hear!
PostPosted: Thu Jun 23, 2005 10:05 pm
Interesting fault, never heard of that one before.. :wink:
PostPosted: Fri Jun 24, 2005 1:34 pm
:shock: Never thought I'd ever hear that from you Doc! :lol:
PostPosted: Fri Jun 24, 2005 6:30 pm
dunno if this is the same sort problem, but weeks ago, i had trouble getting into 3rd from 2nd. This was purely just the flow of the gear stick when goin for 3rd gear. i simply kept missing the slot. once u sort out the perfect spot for when it goes in, get the feel of it. and u wont scew up, be gentle, dont force gears cause u'll know it when u do.
hope that helps.
peace
twista
Image Image
PostPosted: Fri Jun 24, 2005 7:22 pm
Twista,
Selection probs like that are common in old rodchange boxes as the reverse gate `block' is in the shifter housing and any slack between there and the gearbox can result in blocked shifts, particularly 2-3.
But on a remote box, the reverse gate mechanism is inside the box and this problem is uncommon.
But.. remotes do suffer from a weak reverse lockout spring- if trying hard 2-3 you can finish up across in the reverse gate.
:idea: Solution- fit a stronger spring. I use a blue or red 3-1/2" long die spring, cut in 1/2. You can still get reverse, but need to hit it across pretty hard. :wink:
PostPosted: Fri Jun 24, 2005 11:17 pm
peace doc
twista
Image Image
PostPosted: Fri Jun 24, 2005 11:33 pm
i used to have trouble getting from 2nd to 3rd when i first got the car but that was just my fault, wasnt pushing the gearstick right across :P
