It is currently Tue Aug 12, 2025 8:03 am
 Post subject: Gearbox Ratio Change
PostPosted: Tue Jan 07, 2014 8:49 pm
I"m about to change the diff ratio in my gearbox, to make it a little easier on the open road. It's a remote type... just wondering if I need to split the block and box apart or can I get to the pinion if I remove the speedo drive housing?
Thanks, Richard.
 Post subject: Re: Gearbox Ratio Change
PostPosted: Tue Jan 07, 2014 8:51 pm
You can do it through the speedo cover...
Cheers, Ian
PostPosted: Tue Jan 07, 2014 8:56 pm
Nice, thanks! The job just got a lot easier :)
PostPosted: Wed Jan 08, 2014 7:18 am
You will need to diss-engage the gear selector so you can engage 1st gear & 4th gear at the same time, to lock the box up, so you can undo the pinion nut
easy-peasy
PostPosted: Wed Jan 08, 2014 8:46 am
No worries MiniMan thanks!!
PostPosted: Sun Jan 12, 2014 1:55 pm
Could someone tell me what size socket I need to remove the diff pinion nut thanks.
PostPosted: Sun Jan 12, 2014 2:05 pm
deep 1-1/2 inch socket preferably single hex.
Same socket you want for doing balljoints and flywheel bolt.
PostPosted: Sun Jan 12, 2014 6:48 pm
Thanks!!
Users browsing this forum: No registered users and 349 guests
