Boot Floor & Fuel Tank drain https://www.ausmini.com/forums/viewtopic.php?f=2&t=84127 |
Author: | junior [ Wed Jan 08, 2014 4:29 pm ] |
Post subject: | Boot Floor & Fuel Tank drain |
Mini is currently in the paint shop & something I might have overlooked. A new boot floor is in place & I noticed there is no hole for the fuel tank drain. Is the hole necessary, if so can anyone provide a reference or dimension for the location of the hole. |
Author: | drmini in aust [ Wed Jan 08, 2014 6:37 pm ] |
Post subject: | Re: Boot Floor & Fuel Tank drain |
Next time mine comes out it will get a 3/8 UNF grubscrew there instead. If you need to drain the tank it's easier to just siphon it than fight with that damned drain. ![]() [edit] typo |
Author: | John Smidt [ Wed Jan 08, 2014 7:01 pm ] |
I find the drain tube instead of the drain Plug works Great And I know where You can get them NOS |
Author: | boomini [ Wed Jan 08, 2014 7:05 pm ] |
Just had a look a my boot floor since im in the shed. Im guessing the drain is located behind the wheel arch. If so I apologise but I have already cut out that section. |
Author: | junior [ Wed Jan 08, 2014 7:24 pm ] |
John Smidt wrote: I find the drain tube instead of the drain Plug works Great And I know where You can get them NOS John, picked up one at your last clear out!! |
Author: | simon k [ Wed Jan 08, 2014 9:07 pm ] |
junior wrote: Mini is currently in the paint shop & something I might have overlooked. A new boot floor is in place & I noticed there is no hole for the fuel tank drain. Is the hole necessary, if so can anyone provide a reference or dimension for the location of the hole. the tank has a boss on the base of it that would (probably) hit the floor if the hole wasn't there put the tank in and mark it |
Author: | junior [ Wed Jan 08, 2014 9:43 pm ] |
I will take the tank with me when I am down at the panel shop at the end of the week & mark it up. Thanks for the replys. |
