It is currently Wed Aug 06, 2025 4:25 pm
 Post subject: "Stuck" needle
PostPosted: Wed Jan 08, 2014 9:03 pm
Hola.
I'm trying to get the carb needle out of the piston but I cannot.
I've loosened the retaining screw and the needle isn't jammed in, it can still wiggle, but it won't come out.
Am i missing something?
 Post subject: Re:
PostPosted: Wed Jan 08, 2014 9:09 pm
cush wrote:
Hola.
no, thats pretty normal - whenever I have that problem and I want to keep the needle, I take the grub screw out and drill a ~1mm hole part way through the shank of the needle, then use a sharp pointer (my old school compass) to lever it out.
Most of my needles have the same little hole on the shank now...
 Post subject: Re:
PostPosted: Thu Jan 09, 2014 8:35 am
I had this problem with a fixed type needle. I took out the grub screw and it still wouldn't budge. I simply mounted the needle in a soft jawed vice and whacked the piston with a rubber mallet. Still took a few hits before moving, but it worked. But I'm not sure what this would do to the spring loaded type.
Users browsing this forum: No registered users and 69 guests
