Rod change exhaust mount https://www.ausmini.com/forums/viewtopic.php?f=2&t=84139 |
Author: | Irish Yobbo [ Thu Jan 09, 2014 8:57 am ] |
Post subject: | Rod change exhaust mount |
Hi all, I've plonked the engine back into the car and got it all running nicely, but I went to go and tighten up the exhaust and found that I'd forgotten to put the lower exhaust mount back onto the gearbox. Problem is, I can't for the life of my figure out where it goes now! It probably doesn't help that when I took it off there was about an inch of oil and mud caked on... Does anybody have any pics, or can you describe exactly how it mounts to the gearbox? |
Author: | FNQ [ Thu Jan 09, 2014 4:44 pm ] |
Post subject: | Re: Rod change exhaust mount |
Does it go onto lower speedo housing bolt? |
Author: | John Smidt [ Thu Jan 09, 2014 5:33 pm ] |
Bolts To the side of the gearbox, and you use the bolts that hold Your diff side covers to the diff housing and the gearbox case |
Author: | Irish Yobbo [ Fri Jan 10, 2014 7:51 am ] |
John Smidt wrote: Bolts To the side of the gearbox, and you use the bolts that hold Your diff side covers to the diff housing and the gearbox case That's what I thought, but I can't see how the bolts line up, or the position it is supposed to be in. Is there more than one piece of the bracket? |
Author: | MiniBill [ Fri Jan 10, 2014 8:51 am ] |
Any of these pictures any help Irish ? https://www.google.com.au/search?q=rod+ ... 11&bih=427 Cheers Bill |
Author: | Irish Yobbo [ Fri Jan 10, 2014 9:42 am ] |
I've found this site: http://www.moke.com.au/in-the-garage/re ... eplacement Which has a few pictures - I can see some bolts missing where the exhaust has been moved to the side. I'll just need to get the bracket out again and play around a bit. I just couldn't position it anywhere where the bolts would line up last time. |
Author: | drjbeam [ Fri Jan 10, 2014 9:46 am ] |
http://www.classicmotoring.net.au/cmos/ ... ge&pID=566. http://www.classicmotoring.net.au/cmos/ ... e&pID=1274 there the ones you need just put one on last week end with some mods to the bracket with a hack saw http://www.minispares.com/product/Class ... |Back%20to It bolts on with the diff cover |
