Fan-Radiator gaps https://www.ausmini.com/forums/viewtopic.php?f=2&t=84151 |
Author: | Morris 1100 [ Thu Jan 09, 2014 9:17 pm ] |
Post subject: | Re: Fan-Radiator gaps |
The gaps are not a problem. |
Author: | Mick [ Thu Jan 09, 2014 9:34 pm ] |
For full efficiency, the fan should have a spacer beneath the pulley to push it deeper into the cowl. The back (engine) side of the fan should be nearly flush with the cowl. This limits the high pressure side bleeding back out through the blade tips. |
Author: | John Smidt [ Fri Jan 10, 2014 11:19 am ] |
Mick wrote: For full efficiency, the fan should have a spacer beneath the pulley to push it deeper into the cowl. The back (engine) side of the fan should be nearly flush with the cowl. This limits the high pressure side bleeding back out through the blade tips. It appears to Me that You may not have a Clubman type top bracket they are a bit longer AYG2247, The spacer mentioned above is the Aluminium type |
Author: | TheMiniMan [ Fri Jan 10, 2014 1:24 pm ] |
yep, John has it right you need the clubman/Leyland mini type (longer) top bracket & the wide alloy spacer under/behind the fan & we usually use single sided sticky-foam to seal up the gap between the rad shroud & the rad. |
Author: | Gotta_Van [ Fri Jan 10, 2014 2:27 pm ] |
Thanks for all the advice! I'll add another spacer/replace the existing with a thicker one and put something in the gap, if only to hide it a little! Hopefully she will run slightly cooler ![]() |
Author: | John Smidt [ Fri Jan 10, 2014 5:42 pm ] |
Gotta_Van wrote: Thanks for all the advice! I'll add another spacer/replace the existing with a thicker one and put something in the gap, if only to hide it a little! Hopefully she will run slightly cooler ![]() I would be changing the top bracket When You put a bigger spacer in |
Author: | Gotta_Van [ Fri Jan 10, 2014 6:55 pm ] |
Ah yes, I forgot to list that, but fully intended to do it! ![]() |
