Mini Horn Help? https://www.ausmini.com/forums/viewtopic.php?f=2&t=84152 |
Author: | Mick [ Thu Jan 09, 2014 9:15 pm ] |
Post subject: | Re: Mini Horn Help? |
12 volts comes from the fuse, through the horn and up to the steering column. The 12 volts is grounded to the steering column when you press the button causing the horn to sound. You have everything fine up until the column. The purple wire should enter the column to go up the center to the horn button under the steering wheel center. It is at the button that the horn is grounded to the column. It jumps the gap to the rotating column via a copper slip ring and brush. Check to see that the brush and slip ring is connected to their respective wires. Try grounding manually at the top of the column as well. |
Author: | Morris 1100 [ Thu Jan 09, 2014 9:20 pm ] |
The purple wire hooks to the blinker switch wires and makes contact with the column at the slip ring |
Author: | mitchell evans [ Thu Jan 09, 2014 10:45 pm ] |
Thanks for that I reckon that will be it |
Author: | Babes [ Thu Jan 09, 2014 10:59 pm ] |
Where are you getting it inspected mitchell, I need to put a few of mine on club reg. |
Author: | mitchell evans [ Fri Jan 10, 2014 8:43 am ] |
Jason I guy in north Yunderup he has been used a fair bit for the sdmc bit far for you but ask Christine she has a list of the people you can take it to |
Author: | Babes [ Fri Jan 10, 2014 9:42 am ] |
Will do thanks mate |
Author: | boomini [ Sat Jan 11, 2014 10:23 am ] |
Did you get the horn sorted mitch? |
Author: | mitchell evans [ Sat Jan 11, 2014 4:33 pm ] |
All sorted now and on club rego |
