moving a mini with no power and no brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=84174 |
Author: | fozzzie [ Sun Jan 12, 2014 12:11 am ] |
Post subject: | moving a mini with no power and no brakes |
Hi all, I am moving house and therefore the project! It's only a 15 minute drive, but I'll need to shift it via a tow truck. Every bugger I've tried so far (5 companies) has either not replied, or refused the job. I'm in Brisbane BTW. Any ideas? thanks in advance ![]() |
Author: | Sletchman [ Sun Jan 12, 2014 1:42 am ] |
Post subject: | Re: moving a mini with no power and no brakes |
I recall a mate of mine hired a trailer to move one of his project cars (not a mini though) when he was in a similar situation. Just need to have a car capable of towing the trailer (or have a buddy with one). Could be a solution? He just googled car trailer hire or something to that effect, IIRC (it wasn't like he knew the right guy or anything, is what I'm getting at). Also, some levels of RACQ have unlimited towing, if you're a member maybe claim it "broke down"? ![]() |
Author: | clovus [ Sun Jan 12, 2014 7:45 am ] |
I used redcliffe towing for my project and he was great, really careful and helpful. Not so good if you aren't on the peninsula. If you have a towbar, just hire a car trailer. Most have a winch which will help you get it on and off safely. |
Author: | 74Club-man [ Sun Jan 12, 2014 7:57 am ] |
I used a car trailer when I picked my car up for the first time. Done it by myself, with the winch on the trailer. Cheaper than hiring someone to do it as they charge a base rate, especially on a Sunday. |
Author: | TheMiniMan [ Sun Jan 12, 2014 1:01 pm ] |
you can call George , he will tow it for you easy peasy 0413875179 edit--> Oh & he will be the cheapest |
Author: | fozzzie [ Sun Jan 12, 2014 2:10 pm ] |
thanks for the replies! I will try george first and see what he says ![]() |
Author: | Irish Yobbo [ Sun Jan 12, 2014 2:10 pm ] |
I've always used my ute and hires a car trailer. I've never moved a mini - only bigger cars. With a few people and a runup, you can get a 1800kg car on, so a 600kg car should be a piece of cake. Any car with a towbar that's not tiny should do the trick. My ute is only 62kW, that still tows well. |
Author: | Mokesta [ Sun Jan 12, 2014 10:08 pm ] |
If you get stuck, I have a mini sized car trailer in Brisbane. No good for steep driveways. |
Author: | cush [ Mon Jan 13, 2014 6:57 am ] |
No power, no brakes? Isn't that how they come from the factory? |
Author: | Monaco [ Mon Jan 13, 2014 9:06 am ] |
fozzzie wrote: Hi all, I am moving house and therefore the project! It's only a 15 minute drive, but I'll need to shift it via a tow truck. Every bugger I've tried so far (5 companies) has either not replied, or refused the job. I'm in Brisbane BTW. Any ideas? thanks in advance ![]() This is why Australian businesses go broke....a can not do attitude! I am guessing if it had power and brakes you probably would not need a tow truck. |
Author: | 69k1100 [ Mon Jan 13, 2014 5:46 pm ] |
My dad towed a mini 300ks on a 6*4 trailer. Without an engine the combined weight was under 750kg, the legal limit for towing without trailer brakes. Mini is less than 4ft wide but longer than 6ft. |
