Mick wrote:
Sure is. You can get under there with the car up on stands and check the universals. I'm not sure what type you have, but they can come loose. While you're there take a look at the steering linkages and suspension. Give everything a good rattle in and out. Look at you engine mounts as well. Give the engine a rock, but don't expect there to be any rock.
Is it when you roll on or off the throttle? Or at any time in a straight line? Does it go quiet or otherwise under acceleration?
Mick it happened about 2km from home on a sweeping right hand bend, then the noise was persistant until l got home, the noise was constant with and without throttle, l havent driven the car since
, when l get home tonight l will have a look at what you have suggested.
