Hi All,
The other day I re-wired the reverse switch for my rod change back in. It hasn't had the wires since I've owned it - I found the old wires had been cut off, probably because they had been damaged. So I ran some new wires through the bulkhead and down to the switch. The old reverse switch had been broken (the actual switch bit had broken off). So I cut back the thread by a few mm and wound it in. Worked like a charm.
The issue now is that I can't select 2nd gear. It occurred to me that the gear lever may be fouling on the switch, however if I wind the switch out any further, it no longer works. I think the next step is to just buy a new switch (I was wanting to get this done as soon as possible, which is why I didn't in the first place), but is there any other reason this could happen?
