It is currently Sat Aug 02, 2025 4:39 am
 Post subject: Disc pad shims?
PostPosted: Thu Jan 16, 2014 7:40 am
I've just changed to new disc pads. The old ones where fitted with thin metal shims, they may have originally been bonded to the pads I'm not sure ( one seemed stuck) and one has always been missing.
Are these necessary? I assume they are anti squeal but they don't seem to act as any kind of slight spring as I would expect.
If they are worth fitting where do I get them for standard 7.5 discs.
 Post subject: Re: Disc pad shims?
PostPosted: Thu Jan 16, 2014 7:47 am
They stop your pads from squealing, which doesn't seem to be such a problem anymore. I go without, but I have a set of four here in case I need them. I haven't in a dozen years however.
PostPosted: Thu Jan 16, 2014 9:34 am
When you say sqealing I assume you mean when the brakes are applied. The only problem I ever had was sometimes a faint squeak - squeak - squeak - squeak - squeak - squeak - as you drove with the brakes off which would disappear if you lightly touched the brakes.
Hopefully not a problem with the new pads.
PostPosted: Thu Jan 16, 2014 10:26 am
Many pads sold now have a coating on the back to prevent squealing.
If the pads don't come with shims (usual now) they should not need them.
PostPosted: Thu Jan 16, 2014 10:28 am
Ok cheers.
