Disc pad shims?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84211
Author:  phillb [ Thu Jan 16, 2014 7:40 am ]
Post subject:  Disc pad shims?
I've just changed to new disc pads. The old ones where fitted with thin metal shims, they may have originally been bonded to the pads I'm not sure ( one seemed stuck) and one has always been missing.
Are these necessary? I assume they are anti squeal but they don't seem to act as any kind of slight spring as I would expect.
If they are worth fitting where do I get them for standard 7.5 discs.
Author:  Mick [ Thu Jan 16, 2014 7:47 am ]
Post subject:  Re: Disc pad shims?
They stop your pads from squealing, which doesn't seem to be such a problem anymore. I go without, but I have a set of four here in case I need them. I haven't in a dozen years however.
Author:  phillb [ Thu Jan 16, 2014 9:34 am ]
When you say sqealing I assume you mean when the brakes are applied. The only problem I ever had was sometimes a faint squeak - squeak - squeak - squeak - squeak - squeak - as you drove with the brakes off which would disappear if you lightly touched the brakes.
Hopefully not a problem with the new pads.
Author:  drmini in aust [ Thu Jan 16, 2014 10:26 am ]
Many pads sold now have a coating on the back to prevent squealing.
If the pads don't come with shims (usual now) they should not need them.
Author:  phillb [ Thu Jan 16, 2014 10:28 am ]
Ok cheers.
