It is currently Tue Jul 29, 2025 12:41 am
PostPosted: Thu Jan 16, 2014 7:45 pm
Hi Guys,
Going on the Pics in the brochure, it appears I should have a Dizzy with Vacuum advance. How does that connect?
I am thinking of a 123 distributors. Could go the 29D that's currently on there, but I shluld have the vacuum advance..
Cheers BRett
PostPosted: Thu Jan 16, 2014 7:51 pm
Are you talking about the Cooper S?
PostPosted: Thu Jan 16, 2014 9:41 pm
Yes
PostPosted: Fri Jan 17, 2014 6:00 am
Which brochure/picture Brett?
PostPosted: Fri Jan 17, 2014 7:04 am
Hi Phill, this is the brochure :D
viewtopic.php?f=32&t=84039
PostPosted: Fri Jan 17, 2014 7:09 am
Yeah I tried to zoom in but it's not clear in those scans. There would be a visible thin vac advance tube running up to the carburettors if it had one. Do you think you can see a vacuum unit on the side of the dissy?
PostPosted: Fri Jan 17, 2014 7:18 am
on the back spec it says
Automatic anvance and retard, vacuum controlled
PostPosted: Fri Jan 17, 2014 7:27 am
Nah. They just haven't bothered with a footnote that the s has no vac advance. Should have a 23D fitted on Cooper S with No vac advance.
PostPosted: Fri Jan 17, 2014 7:37 am
Also remember this is marketing. If they had said in a footnote "no vac advance on Cooper S" then to the average person that makes it sound like the cooper s is missing out on a feature.
PostPosted: Fri Jan 17, 2014 5:55 pm
Don't believe him Brett, everybody knows that the Mk 1.5 Cooper S has vacuum advance.
PostPosted: Sat Jan 18, 2014 6:33 am
:lol:
PostPosted: Sat Jan 18, 2014 12:08 pm
The reason the S didn’t have vacuum advance is that it is a fuel economy device that works during part throttle cruise. No one was ever expected to drive an S other than balls to the wall…… And, fuel was cheap.
Back then the local BP (Kensington) gave a discount if you bought $2 worth. The trouble was that you couldn’t fit 2 bucks worth in a Mini… But then no one said you could only fill up one Mini ;)
No one should be without vac advance today.
Cheers, Ian
