Squeaky clutch pedal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84237
Author:  ryan [ Fri Jan 17, 2014 10:26 pm ]
Post subject:  Squeaky clutch pedal
What should I put on it to get rid of the squeak?
Author:  Kennomini [ Sun Jan 19, 2014 10:34 am ]
Post subject:  Re: Squeaky clutch pedal
Probable some spray grease would be easiest.
Author:  Harley [ Sun Jan 19, 2014 11:52 am ]
Spray grease, or to a letter extent, wd40 may work for a while, but the longest running solution is to pull the pedal box out and grease it when re-assembling it. The squeak will be the bush on the shaft which could be tricky to lubricate with it all in the car.
