Tyre width on Mamba 10 x 6 https://www.ausmini.com/forums/viewtopic.php?f=2&t=84239 |
Author: | BBY755 [ Sat Jan 18, 2014 3:19 pm ] |
Post subject: | Tyre width on Mamba 10 x 6 |
G'day, Found that at normal pressure (28 psi) the Falken 165s stick out 17mm from the rim, while the Bridgestones only stick out 4mm! Could anyone with Mambas 10 x 6 (mine are original ones) who have A008s on please measure and let me know, as thinking of getting a set and don't want them sticking out like the Falkens...... Thanks in advance..... |
Author: | JimL [ Sun Jan 19, 2014 2:14 pm ] |
Post subject: | Re: Tyre width on Mamba 10 x 6 |
Do you mean the sidewall to the lip of the rim? I have the new style mambas with 165/70 A008's. At 26 psi the sidewall sticks out 2mm. |
Author: | BBY755 [ Sun Jan 19, 2014 5:59 pm ] |
Yep, Sidewall to lip of rim. Thanks for that. Appreciate your help. I had heard that the 008s are not super wide and this confirms it. Hope this info also helps others! |
Author: | goodie [ Sun Jan 19, 2014 6:31 pm ] |
I have original Mamba's with A008's , and as best as i can measure = 18mm . |
Author: | JimL [ Sun Jan 19, 2014 8:06 pm ] |
The new ones must be quiet different from the originals! |
Author: | BBY755 [ Sun Jan 19, 2014 8:36 pm ] |
Oh.... The new Mamba 6s are listed as ET (offset) -7. I will try and measure my originals offset tomorrow and post it up. Thanks guys. |
Author: | BBY755 [ Mon Jan 20, 2014 7:49 pm ] |
Hi JimL, Duh....been a busy 2 months at work and my brain hurts!!! You are right....offset means SFA..... The method you show is the method I am using so will be a valid comparison. Was checking offsets as wanted to reduce any tyre sticking out from flares, and so I could see the difference in different wheels as well as different tyre overhangs. Thanks again. |
