Drivers engine steady mount https://www.ausmini.com/forums/viewtopic.php?f=2&t=84245 |
Page 1 of 2 |
Author: | Callin [ Sun Jan 19, 2014 9:51 am ] |
Post subject: | Drivers engine steady mount |
Hi guys, can anybody put up some pics of a firewall mount, trying to make a decision on how to fix mine.... ![]() ![]() If the bracket is meant to be 90° I might make a new one out of some thicker angle and either spot weld or bolt it in place of the old, other wise I may have to weld this tab back on Cheers |
Author: | drmini in aust [ Sun Jan 19, 2014 12:44 pm ] |
Post subject: | Re: Drivers engine steady mount |
I would bolt it all together with the dogbone's spacer in for alignment, then MIG weld it back on. Clean ALL the paint etc off the weld area, first. |
Author: | Callin [ Sun Jan 19, 2014 12:47 pm ] |
Might that damage the rubber bush? |
Author: | drmini in aust [ Sun Jan 19, 2014 12:49 pm ] |
Leave the rubbers out, you just want the spacer + bolt in it. |
Author: | Callin [ Sun Jan 19, 2014 12:51 pm ] |
Yeh just pulling it apart now, the bar is fairly bent too |
Author: | Callin [ Sun Jan 19, 2014 12:52 pm ] |
Author: | boomini [ Sun Jan 19, 2014 12:55 pm ] |
I believe the bracket is available new from minisport |
Author: | Callin [ Sun Jan 19, 2014 3:48 pm ] |
![]() ![]() Far from my best welding and sure isn't pretty but it will do for now Thanks guys |
Author: | drmini in aust [ Mon Jan 20, 2014 4:03 pm ] |
I would just add a bit in the middle on top. |
Author: | ryan [ Mon Jan 20, 2014 4:17 pm ] |
I can't get the stud to come on mine. Anyone had this happen before? |
Author: | Callin [ Mon Jan 20, 2014 4:18 pm ] |
What do you mean exactly? |
Author: | ryan [ Mon Jan 20, 2014 4:42 pm ] |
Sorry, I should of explained that better, and actually read what I typed before clicking submit. The stud that runs through the spacer and and the two brackets is stuck. I have tried knocking it out with a hammer but it just won't budge. |
Author: | Callin [ Mon Jan 20, 2014 4:54 pm ] |
It won't go through, you will have to undo the top bracket =( I will have to do the same to get it back out/put the steady in |
Author: | ryan [ Mon Jan 20, 2014 4:58 pm ] |
Callin wrote: I won't go through, you will have to undo the top bracket =( I will have to do the same to get it back out/put the steady in As in remove the master cylinders? |
Author: | Callin [ Mon Jan 20, 2014 5:00 pm ] |
Yeh, I'm not totally sure how much its gotta be pulled apart though |
