Broken Speedo Cable
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84248
Author:  kaka [ Sun Jan 19, 2014 3:21 pm ]
Post subject:  Broken Speedo Cable
My speedo cable has broken in the gearbox. Unfortunately for me the gearbox is still in the car.
I have unscrewed the cable casing at the gearbox but can see the broken end in the gearbox recess. If I undo the engine mount and jack the engine, will I be able to get my hand in location and maybe use tweezers to pull the cable end out of the gearbox recess. Any tricks would be great.
Author:  Hanra [ Sun Jan 19, 2014 3:29 pm ]
Post subject:  Re: Broken Speedo Cable
Have you tried to undo the singular bolt holding the entire threaded assy to the gear box and then remove the whole kit and kapoodle? Its a tight squeeze but you can undo that bolt and remove it all from under the car.
Author:  kaka [ Sun Jan 19, 2014 3:33 pm ]
Thanks. Will try and undo that 7/16 bolt.
Author:  Hanra [ Thu Jan 23, 2014 10:03 am ]
Howd you go?
Author:  kaka [ Thu Jan 23, 2014 6:23 pm ]
Been too busy. Hope to have a crack this long weekend.
Author:  kaka [ Mon Jan 27, 2014 5:51 pm ]
I removed the bolt and retainer, then pulled the circular centre piece out. My broken speedo cable and its thick end piece are wedged ( about an inch long). I couldn't remove them with pliers.
