how to advance timing? https://www.ausmini.com/forums/viewtopic.php?f=2&t=8430 |
Author: | Fat80y [ Fri Jun 24, 2005 1:58 pm ] |
Post subject: | how to advance timing? |
I'm having a blonde day here - to adavnce timing, I rotate dizzy anti-clockwise - correct? |
Author: | fuzzy-hair-man [ Fri Jun 24, 2005 2:23 pm ] |
As far as I remeber clockwise it is... Generally the revs will increase the more you advance the timing from standard, are you setting your timing using a timing light if so you should be able to see the numbers on the fly wheel. |
Author: | mini_van_1970 [ Fri Jun 24, 2005 10:16 pm ] |
I just put a bloody big (reasonable size) spotch of paint on the timing mark works for me Pat |
Author: | 68matic [ Fri Jun 24, 2005 10:27 pm ] |
you will have to find out the direction your rotor button turns to definitely find out which way is advancing but in Herman and Trev (my only a series models) turning the dissy body clockwise advances it |
Author: | gafmo [ Fri Jun 24, 2005 10:37 pm ] |
Advance your Clock ![]() |
Author: | Fat80y [ Sat Jun 25, 2005 9:50 am ] |
Cheers guys I new I had a 50-50 chance. Don't have a timing light, so doing some seat of the pants tuning... |
Author: | 68matic [ Sat Jun 25, 2005 9:52 am ] |
if youre game loosen the clamp bolt, turn on car and turn it either way retarding will sound like its slower advancing will cause it to pick up its revs retarding too much and advancing too much will cause it to slow as well. you will have to find a nice balance |
Author: | Fat80y [ Sat Jun 25, 2005 9:57 am ] |
Yep I originally thought it was clockwise, so advanced it, but must have been too far as it had no power, and wouldn't rev over 3,000. Didn't ping tho, so I thought I had retarded it. Mental note - baby steps... |
