eletric fuel pumps https://www.ausmini.com/forums/viewtopic.php?f=2&t=84309 |
Author: | nicholasatkins [ Sat Jan 25, 2014 12:14 pm ] |
Post subject: | eletric fuel pumps |
Hi. i have had a few dramas with the cheap electric fuel pumps and want some thing a little quieter and reliable. looking at the facet pumps what pressure should i be looking at getting? (im using twin su) do i need a regulator? there is quite a few types any to stay away from/ what would you recommend. thanks |
Author: | FNQ [ Sat Jan 25, 2014 12:58 pm ] |
Post subject: | Re: eletric fuel pumps |
the facets will still give you the familiar ticking. pressure about 3 psi. regulator - optional |
Author: | Babes [ Sat Jan 25, 2014 2:05 pm ] |
Personally I dont think you can go past a genuine SU electric pump. |
Author: | drmini in aust [ Sat Jan 25, 2014 5:41 pm ] |
I've had no probs with the square 3psi Facet ones, the one on my car has been there 20 yrs since I bought the car and it was s/h then. I would not bother with a regulator unless using a higher pressure pump, and if you do, ffs fit a pressure gauge. Cheap regulators (some) have hopeless calibration. |
Author: | nicholasatkins [ Sat Jan 25, 2014 7:20 pm ] |
thanks. this one here should be ok then? http://www.ebay.com.au/itm/FACET-FUEL-P ... 3a84e709c8 |
Author: | guna mk1 [ Sat Jan 25, 2014 8:30 pm ] |
That one will only be good if your mini is 24 volts |
Author: | drmini in aust [ Sat Jan 25, 2014 9:17 pm ] |
Here are specs...http://www.facet-purolator.com/cube-fuel-pumps.php |
Author: | goodie [ Mon Jan 27, 2014 6:00 pm ] |
Babes wrote: Personally I dont think you can go past a genuine SU electric pump. Thats what i reckon as well , you can buy new parts for them from SU Midel , they are easy to repair , but more often than not , they just need a clean internally , they tend to gum up over time . |
Author: | Convertible Mini [ Mon Jan 27, 2014 7:56 pm ] |
I sell Facet style fuel pumps which are suited for SU carbs. about 2.5 to 3 psi. I sell these for $50.00 posted. I also supply two rubber mounts with it for it FREE. these minimize the noise they make through the body. Send me a message if you want one. Tony. |
Author: | nicholasatkins [ Tue Jan 28, 2014 9:22 am ] |
cheers guys. |
