It is currently Sat Jul 26, 2025 4:52 pm
PostPosted: Tue Jan 21, 2014 3:02 pm
I've been advertising on Gumtree to buy a 1275 engine for my mini and have recently been sent some photos of an engine on offer (I would include the photos but don't know how to add them on here! Advise please?).
Can anyone give me any details on the engine?
The number as far as I can read is:
12H902******62 (the *'s are the numbers I can't read!).
The seller has told me it's from a Moke and was running in a 61 850 Mini before he removed it.
Thank you in advance for any information :D
PostPosted: Tue Jan 21, 2014 4:02 pm
12H902 was used in the 1978 1275LS and possibly also the Moke from the same year as well.
PostPosted: Tue Jan 21, 2014 4:06 pm
Engine Number ID:
http://www.minis.com.au/page5/page5.html
Going from that (which could be wrong) says 12H902 is from a Leyland LS 1275
12H prefix was also in Mokes
Putting up photos:
viewtopic.php?f=25&t=10405
PostPosted: Tue Jan 21, 2014 4:34 pm
Cheers guys, with the link you added timmy201 I can now see the U after 902 :0)
Morris 1100: How do you know it's a 78'?
Can anyone one else tell me if these were a good engine?
PostPosted: Tue Jan 21, 2014 4:41 pm
P.S. I'm guess this makes it a A series engine? Too early to be an A+!
PostPosted: Tue Jan 21, 2014 4:44 pm
http://en.wikipedia.org/ wrote:
To end Mini production in Australia, a limited edition runout model was produced − the 1275LS. Fitted with a pollution control 1,275 cc engine sourced from Europe, the LS had a single 1.5-inch (38 mm) carburettor and 8.4-inch (210 mm) disc brakes. Production of this model commenced in July 1978 and concluded in October 1978 with an approximate total of 810 vehicles produced.
PostPosted: Tue Jan 21, 2014 5:45 pm
minimadmarty
the 1275 motors are all good, but that doesn't mean they aren't put together poorly, worn out, bored out to the end of its working life without sleeves, etc.
i take it , you were after a whole Long/short motor that was going and not needing an expensive (relatively) rebuild straight away.
if you can get all the details from seller about the last build on it, if not yhen see it working in the car, otherwise it could be a lottery..... worth while getting a mini mad mechanical type to look with you.. best of luck
PostPosted: Tue Jan 21, 2014 6:03 pm
Hi FNQ,
I'm after a 1275 to rebuild myself (never done one before although I have rebuilt Ducati engines). It's more a project of learning, if I get it right I'll have a good spare motor for my Mini. If I stuff it up, I dig a big hole in the garden and pretend it never happened (as I did with my first wife! Kidding!!). The guy selling is asking $600 so I can't really go wrong! (I hope!).
Hi FNQ,
PostPosted: Tue Jan 21, 2014 6:11 pm
Because they only built the 902 in 78.
PostPosted: Tue Jan 21, 2014 6:16 pm
Cheers again Morris 1100,
Does anyone know how the pollution control worked? Does it restrict horsepower in any way?
PostPosted: Tue Jan 21, 2014 6:34 pm
It used a few HP to drive an air pump which injected air into the exhaust ports of the head.This helped burn unburned fuel, also diluted the exhaust plume with air.
These days, most cars have ditched the pump etc, parts to fix are NLA and ADR27A was all intended for leaded fuel, which we no longer have..
Nobody checks pollution figures here on old cars anyway, it's not like in the UK.
PostPosted: Tue Jan 21, 2014 6:42 pm
Closed cirucuit breathing was a form of pollution control (crank case breather back into the manifold) I believe the heads were different too, I recall an air port in the exhaust to reduce the harmful by products (carbon monoxide)
PostPosted: Tue Jan 21, 2014 7:23 pm
MM Marty
if all is turning over in the engine you should have a ball building one, and so long as internals are fine that is a good deal.
PostPosted: Tue Jan 21, 2014 9:37 pm
$600 mate seems cheap. As long as it turns by hand your on the right track.
If you need help to look at it just ask. Im happy to help.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
Users browsing this forum: 63lcn and 98 guests
