It is currently Sat Jul 26, 2025 4:51 pm
 Post subject: Broken Speedo Cable
PostPosted: Sun Jan 19, 2014 3:21 pm
My speedo cable has broken in the gearbox. Unfortunately for me the gearbox is still in the car.
I have unscrewed the cable casing at the gearbox but can see the broken end in the gearbox recess. If I undo the engine mount and jack the engine, will I be able to get my hand in location and maybe use tweezers to pull the cable end out of the gearbox recess. Any tricks would be great.
 Post subject: Re: Broken Speedo Cable
PostPosted: Sun Jan 19, 2014 3:29 pm
Have you tried to undo the singular bolt holding the entire threaded assy to the gear box and then remove the whole kit and kapoodle? Its a tight squeeze but you can undo that bolt and remove it all from under the car.
PostPosted: Sun Jan 19, 2014 3:33 pm
Thanks. Will try and undo that 7/16 bolt.
PostPosted: Thu Jan 23, 2014 10:03 am
Howd you go?
PostPosted: Thu Jan 23, 2014 6:23 pm
Been too busy. Hope to have a crack this long weekend.
PostPosted: Mon Jan 27, 2014 5:51 pm
I removed the bolt and retainer, then pulled the circular centre piece out. My broken speedo cable and its thick end piece are wedged ( about an inch long). I couldn't remove them with pliers.
Users browsing this forum: 63lcn and 99 guests
