It is currently Sat Jul 19, 2025 5:42 am
 Post subject: seam sealer
PostPosted: Sun Jan 26, 2014 8:02 pm
Hey guys
Just wondering what everyone uses to seal the seam between the front gaurds and the scuttle panel.
Thanks
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
 Post subject: Re: seam sealer
PostPosted: Mon Jan 27, 2014 6:05 pm
Thsi has been up on Ausmini a few times, with Dripcheck and Sikaflex being the recommended product.
In common with the same products used between the seam covers and the body, the pitfall is if it cracks or shrinks, or otherwise wrecks the paint over the top.
Dripcheck was used on my shell in 2009 ,and is holding up pretty well at four years.
Otherwise have a look at these threads:
viewtopic.php?t=32486&view=previous
viewtopic.php?f=2&t=80953&view=next
PostPosted: Mon Jan 27, 2014 6:08 pm
Thanks mick. Appreciate it
Minis..
1975 van
PostPosted: Mon Jan 27, 2014 6:19 pm
Mine was done by my painter 3 years ago with Sikaflex, so far paint's not cracked...
PostPosted: Tue Jan 28, 2014 6:06 pm
I used 3M Drip Check seal on my last car and it cracked not long after I painted the car. I followed the instructions to the letter because I was concerned it might crack, but it cracked anyway. Its the worst product I have ever used. In the UK we used to use Tiger seal, not sure if its available here.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Tue Jan 28, 2014 10:58 pm
regarding seams, is it wise to remove em ?
It's easy once you know how.
PostPosted: Mon Oct 12, 2015 7:21 pm
Saw a a classic resto American muscle the other day on telly and the resto mob were silicon bronze brazing the panel joints .... I thought what a fantastic idea for the guard / scuttle joint.... No cracking then ;)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Oct 16, 2015 6:28 pm
That joint line was not originally sealed with anything - just painted.
Drop-Check does eventually dry and crack, as along roof gutter mould drip rails.
Sikaflex seems to be popular but haven't had it on very long yet.
