It is currently Mon Jul 21, 2025 11:26 pm
PostPosted: Tue Feb 04, 2014 7:46 pm
How hard are these to replace? What steps need to be followed?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Feb 04, 2014 8:00 pm
You need to remove the inner door catch mechanism and then thread the coil spring over the square steel axis which goes to the outer handle. The spring secures on its outer end to one of the three securing screws for the outer handle.
I can't remember however if you need to remove the inner door handle mechanism before putting the clock spring on? Any one else remember if you do?
PostPosted: Tue Feb 04, 2014 9:47 pm
Depends what you are actually doing. The original spring is inside the door latch mechanism - which means drilling out rivets to open it up ...and then finding something original looking to put it all back together....
The previous post is referring to the after market snail spring that fits on the outside (of the latch) and assists the original spring to hold the door handle horizontal.
If this is what you have, just remember to wind it around a few times to tension it before fixing the outer end....
Cheers, Ian
PS They work really well....
PostPosted: Wed Feb 05, 2014 6:37 am
Thanks guys. Ian, you are right. It's the aftermarket one that I'm using.
Is it a straight forward job?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Wed Feb 05, 2014 9:23 am
The snail spring is a stock part, not aftermarket.
p/no is HYA3512, it is shown in the Mini King book p 262, and listed in PUB1038 (Mini-K factory parts book).
PostPosted: Wed Feb 05, 2014 7:48 pm
The Mini King
Cheers, Ian
Are You of the opinion that the snail spring was never fitted at the factory, only after market ?
PostPosted: Wed Feb 05, 2014 9:13 pm
Not a all. Just that the large spring is hard to get to to repair - maybe not for you pros...
For us amateurs though....the much finer aftermarket helper spring takes up the slack in the main spring and is invisible once installed....
Cheers, Ian
PostPosted: Thu Feb 06, 2014 12:16 pm
Cheers, Ian
Mate,
How many people have to point this out?
The spring you are referring to is a factory part fitted to all Australian doors with wind up windows and pull down handles.
It is not aftermarket!
There is enough missinformation posted here to confuse young players, why add to it?
Dave
PostPosted: Thu Feb 06, 2014 8:43 pm
If you insist...
PostPosted: Fri Feb 07, 2014 8:09 pm
Hey Ryan
I remember you being there one day a while back up at the Mini King shop when I asked a similar question abaout my door handle snail spring - sorry, but forget the dude's name who talked me through the procedure, but anyways I remember saying bugger that, sounds out of my mechanical league!
anyways, if you do manage to give it a go, I would like to help / assist / observe so as I could have a go to fix mine too one day. Let us know if and when you're up for it
1968 Mini-Matic
PostPosted: Sat Feb 08, 2014 1:39 pm
Hey Steve,
Its actually out at Classic Fabrications, Jason is fixing the door and i'm getting him to do the handle...hopefully
Ryan Filippi
Minis In The Gong
[email protected]
