MECHNACIAL FAULT?, timing? https://www.ausmini.com/forums/viewtopic.php?f=2&t=8438 |
Author: | clubmn [ Fri Jun 24, 2005 5:54 pm ] |
Post subject: | MECHNACIAL FAULT?, timing? |
I was wondering if sombody can help. Timing is up the crap, and i cannont work out why, the car will not RUN. I origionaly thought it may have being the webers but i have tryed a multitude of carbies and it is no better. I have: Set the tapit clearance. Timed the dizzy replaced all ignition system, plugs points leads etc. Replaced the carbie with a single 1 3/4su (this thing cannont f*&k up) The car will not run and clearly sounds like it is fireing when it shouldent. Could it be a mechnical fault, the engine has done less that 1000km since rebuild. compression is 160psi on all 4 pots. I was thinking it could be a mechnical falure, but i am, really not sure, |
Author: | Harley [ Fri Jun 24, 2005 5:57 pm ] |
This might sound stupid, but the leads are connected to the right spark plug, right? |
Author: | clubmn [ Fri Jun 24, 2005 5:59 pm ] |
Post subject: | mini |
IF 1,3,4,2 is right, YEP, anyhelp is good help. |
Author: | 9YaTaH [ Fri Jun 24, 2005 7:11 pm ] |
Post subject: | more information?? |
ummm....I think people here might need a little more info.... for example, do you have a non-std camshaft and has it been dialled in? have you checked that the distributor isn't 180 degrees out?? stuff like that.....the more you can tell peeps the better... when was the last time it ran OK?? what have you done since then??? ![]() |
Author: | Wolfman [ Fri Jun 24, 2005 7:17 pm ] |
Try another Dizzy cap |
Author: | clubmn [ Fri Jun 24, 2005 7:59 pm ] |
it was running fine one day, parked it then wouldnt start in the morning. it has a VP4 scatter cam all ignition system has been replaced including dizzy cap etc. i really have no idea what to do ![]() |
