It is currently Sun Jul 27, 2025 9:46 am
PostPosted: Tue Feb 04, 2014 12:42 pm
Hi
Just a quick question, i am about to fit the front wheel bearings, the ones i have seem to have a small centre piece the protrudes out… does this piece face into the hub or out?
PostPosted: Tue Feb 04, 2014 12:46 pm
These are the bearings
PostPosted: Tue Feb 04, 2014 1:19 pm
They're the integral spacers. They face inwards.
PostPosted: Tue Feb 04, 2014 1:37 pm
thanks for that
what about the white plastic washer/seal…. is that on the inside or outside bearing set?
regards
PostPosted: Tue Feb 04, 2014 3:01 pm
I can't see the image, but is it a stand off spacer for the seal? In that case it may replace the inside seal to stand it out a little further from the bearing. In original setups, there wasa steel band to hold the inner seal about a quarter inch or so away from the inner bearing.
PostPosted: Tue Feb 04, 2014 5:49 pm
white plastic piece will actually slide onto the cv joint and protects the inner seal.
PostPosted: Tue Feb 04, 2014 6:54 pm
ok so on the CV joint side, and against the CV joint?
PostPosted: Wed Feb 05, 2014 12:36 pm
your picture doesn't appear visible ( well at least to me and Mick
if you re post using photbocket or similar i am sure exact answers will ensue
PostPosted: Wed Feb 05, 2014 12:38 pm
yeah i did use photo bucket… and not sure what happened!
copy URL and paste
