Wheel bearings…. which way around
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84446
Author:  Huelin2008 [ Tue Feb 04, 2014 12:42 pm ]
Post subject:  Wheel bearings…. which way around
Hi
Just a quick question, i am about to fit the front wheel bearings, the ones i have seem to have a small centre piece the protrudes out… does this piece face into the hub or out?
Author:  Huelin2008 [ Tue Feb 04, 2014 12:46 pm ]
Post subject:  Re: Wheel bearings…. which way around
These are the bearings
Author:  Mick [ Tue Feb 04, 2014 1:19 pm ]
They're the integral spacers. They face inwards.
Author:  Huelin2008 [ Tue Feb 04, 2014 1:37 pm ]
thanks for that
what about the white plastic washer/seal…. is that on the inside or outside bearing set?
regards
Author:  Mick [ Tue Feb 04, 2014 3:01 pm ]
I can't see the image, but is it a stand off spacer for the seal? In that case it may replace the inside seal to stand it out a little further from the bearing. In original setups, there wasa steel band to hold the inner seal about a quarter inch or so away from the inner bearing.
Author:  mini_mad_matt [ Tue Feb 04, 2014 5:49 pm ]
white plastic piece will actually slide onto the cv joint and protects the inner seal.
Author:  Huelin2008 [ Tue Feb 04, 2014 6:54 pm ]
ok so on the CV joint side, and against the CV joint?
Author:  FNQ [ Wed Feb 05, 2014 12:36 pm ]
your picture doesn't appear visible ( well at least to me and Mick
if you re post using photbocket or similar i am sure exact answers will ensue
Author:  Huelin2008 [ Wed Feb 05, 2014 12:38 pm ]
yeah i did use photo bucket… and not sure what happened!
copy URL and paste
