It is currently Sun Jul 20, 2025 4:20 am
 Post subject: One man brake bleeding.
PostPosted: Sun Feb 09, 2014 12:33 pm
I couldn't get all of the air out of my brake lines until Sitnlo bled them using his home made pressure brake bleeding thingy.
Similar to this,
http://www.youtube.com/watch?v=Mdcn1USVQ-w
PostPosted: Sun Feb 09, 2014 1:44 pm
Thanks for sharing. Might hit the garden shed and nick the wife's roses sprayer while she's not looking!
PostPosted: Sun Feb 09, 2014 2:06 pm
Thing to take notice of, the seals in the sprayer might be lubricated with a lubricant which might affect the brake seals.
Clean everything with metho and lubricate with rubber grease or brake fluid.
PostPosted: Sun Feb 09, 2014 3:25 pm
Good hints Morris 1100.
Sitnlo used a long hose so that whilst opening and closing bleed nipples he could apply pressure as needed. Worked a treat. No need to push the pedal.
PS. he didn't fit a gauge to his pressure pot.
PostPosted: Sun Feb 09, 2014 3:31 pm
With my own pressure sprayer for the garden I drilled a half inch hole and pulled a tubeless Schrader valve into it. No pumping the handle, I just blow it up with the tyre gauge and compressor.
PostPosted: Mon Feb 10, 2014 1:01 am
I saw a good one of these where the brake fluid was in a second jar between the sprayer and the Master Cylinder.
Behold! The mighty 850!
PostPosted: Mon Feb 10, 2014 8:00 pm
http://www.ebay.com.au/itm/251358077336 ... 1439.l2648
mate has one, works well
PostPosted: Mon Feb 10, 2014 10:10 pm
Wow just watched that video... painful im gonna have to go check I have a number 15 spanner and a 80 different drill bits to get from 1/8 to a half drill bit....
Im sorry but if you have to listen to that idiot to work out how to build a brake bleeder you certainly shouldnt be bleeding brakes...
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Feb 11, 2014 7:27 pm
How much is an EziBleed?? Not much..
Or you can go the other and get a vacuum pump - which I think works better...
Cheers, Ian
PostPosted: Tue Feb 11, 2014 7:41 pm
This is my Shaky Industries One Man Bleederâ„¢ :P Its survived 13 years with much the same brake fluid in it :lol:
I wouldn't mind putting together a decent one like above however...
I might give it a go.
PostPosted: Tue Feb 11, 2014 8:05 pm
You could at least use a clear piece of hose Mick! My bleeder must be a different brand though because it's made from and old plastic laundry liquid bottle.
PostPosted: Tue Feb 11, 2014 9:21 pm
mini_mad_matt wrote:
You could at least use a clear piece of hose Mick! .
Perhaps it was once... :P
