It is currently Sun Jul 20, 2025 4:19 am
 Post subject: Have I been shafted?
PostPosted: Tue Feb 11, 2014 8:04 am
Hydrolastosity
...Well, I think I went a little too fast over that table-top speed bump down the street from work, and the outer CV ring couldn't hold. I know the outer spline doesn't do anything once its all together, but its machined itself off as i coasted to my work. I'm buying a new CV outer assembly, do I need to replace the shaft?
To justify my stupidity, (and not solely relying on my childhood hero's, the Dukes of Hazard) I was testing the hydrolastic system. Which is awesome by the way.
Thanks in advance for the suggestions on the shaft (please keep driving tips for another post).
Cheers, d
 Post subject: Re: Have I been shafted?
PostPosted: Tue Feb 11, 2014 8:27 am
Replace the shaft, and put a new circlip in.
Re-using this will cause more of the same problem.
PostPosted: Tue Feb 11, 2014 8:41 am
Which side are we talking? I may have a spare. I ordered one last year for the same reason, and received the wrong side :roll: It was my bad however...
I did find however that the detent ring didn't really have any tension in it allowing the shaft to remove itself. I ended up forming one myself from spring steel (piano) wire.
PostPosted: Tue Feb 11, 2014 8:53 am
Hydrolastosity
Its the right side (longer shaft)... Thanks Harley, thats what I suspected :oops:
EDIT:
Disc brakes, 67 Cooper S.
PostPosted: Tue Feb 11, 2014 3:35 pm
Drum brakes or discs?
