Steering question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84515
Page 1 of 2
Author:  davem [ Sun Feb 09, 2014 7:23 pm ]
Post subject:  Steering question
Ok got a little problem and l think l know the answer but l would like some advice regardless. This afternoon l installed a 7.9inch 4 pot minisport drive assemblies. But now I've got this problem, steering wheel is at dead centre, my wheels are now opposing each other 11 o'clock and 1 o'clock.
Now what l don't understand is why this has happened. Is it because I've gone from solids to vented discs, or because my hubs are now from a 8.4 inch setup or have l done something stupid? Can l wind out the the tie rod to correct this? Then get to a tyre shop for a alignment. Thanks!
Author:  Convertible Mini [ Sun Feb 09, 2014 8:11 pm ]
Post subject:  Re: Steering question
Make sure you don't run out of thread on the Tie rod ends . You might need to use the longer Ball joints.
I think you are going to need arches too.
Author:  John Smidt [ Sun Feb 09, 2014 9:14 pm ]
Did The brakes come With steering arms or did You use Your
steering arms, What are the part numbers cast in the steering arms
Author:  Harley [ Sun Feb 09, 2014 10:48 pm ]
The short answer is that disc and drum brakes use different steering arms.
Easiest thing for you is to swap them over.
Author:  davem [ Mon Feb 10, 2014 4:13 am ]
No the brakes didn't come with steering arms. I was running 7.5inch solids with no dramas
Author:  davem [ Mon Feb 10, 2014 4:15 am ]
I shall get back to you with a part number, though they are standard oem items (76 clubman)
Author:  John Smidt [ Mon Feb 10, 2014 9:53 am ]
I Think You may find that some of the Australian built Minis
with drum brakes also used the same steering arm as the disc brake models
That is why I enquired about the Part Number
Author:  boomini [ Mon Feb 10, 2014 2:07 pm ]
Put it on the ground and see what happens.
Author:  davem [ Mon Feb 10, 2014 3:21 pm ]
John on the end of the tie rod it is stamped bk 37 41 2
Author:  davem [ Mon Feb 10, 2014 3:22 pm ]
Yer done that no good!
Author:  winabbey [ Mon Feb 10, 2014 3:26 pm ]
It's the steering arm part numbers he needs to know. There were different lengths for different applications.
Author:  davem [ Mon Feb 10, 2014 3:43 pm ]
Author:  davem [ Mon Feb 10, 2014 3:52 pm ]
My bad steering arms were supplied my minisport as part of the kit. It is numbered v96a
Author:  winabbey [ Mon Feb 10, 2014 3:58 pm ]
This may help.
Author:  davem [ Mon Feb 10, 2014 4:17 pm ]
winabbey wrote:
This may help.
Thanks for that info, l searched that part number l found on the steering arm on mini sports website and nothing came up, though l think they supplied this.
http://www.minisport.com/bta895-steerin ... -s-lh.html
I'm thinking that these might help my problem, john do you sell these?
http://minisport.com.au/prod730.htm
