It is currently Tue Aug 05, 2025 7:00 pm
PostPosted: Fri Feb 14, 2014 4:59 pm
Hi all you clever Mini people. I have a problem that I find particularly strange. My little beast who goes by the name of Thomas, a 1964 850 with a 1974 998 engine plonked in several years ago, has recently developed a problem. Whenever I put it in reverse gear he coughs and splutters and even occasionally backfires! Seems to be under extreme load, and if I push him the engine stalls. Only in reverse, all forward gears are no problem whatsoever. I though initially maybe fuel line as the first time it happened I was reversing (or attempting to) up a rather steep incline...that would be my driveway. But it happens on flat ground as well, anytime in reverse. Maybe still fuel pump??
Any suggestions would be greatly appreciated....oh, I am am certainly no mechanic, I can follow instructions if detailed and I have done quite a bit of work to the little beast following the Haynes manual, eg new wheel cylinders, pot joints, front ball joints, brake pads, radiator, steering rack and column and a few other bits, but I'm reluctant to tinker with the engine itself.
PostPosted: Fri Feb 14, 2014 5:23 pm
Does it still have push button starter on floor?
I one had a mini that was coughing and farting when on open road, turned out the exhaust was touching the back of the button at times and shorting the main electrics.
Just a thought.
Cheers Pete
PostPosted: Fri Feb 14, 2014 8:15 pm
Hey, that's a clue! I recently replaced the floor starter button! The radio has also started cutting out intermittently and I haven't been able to find the cause of that. I shall check that tomorrow. Thanks!
PostPosted: Fri Feb 14, 2014 8:21 pm
I am actually hoping that is the problem now...its so different to the usual suspects :lol:
PostPosted: Sat Feb 15, 2014 12:35 pm
That will happen when a deluxe or later exhaust is fitted (ie ones designed to go around a remote gearchange assembly). It ends up shorting across the starter button terminals. Make sure it is an 850 exhaust that goes more towards the centre of the tunnel.
Had this problem with an 850 i used to own, but it happened in between turns 3 and 4 at Eastern Creek during a parade lap. Highly embarrassing.
I would also check your engine mounts and steady bushes because it sounds like the engine is rocking causing the exhaust pipe to move up and touch the starter terminals. It only goes in that direction in reverse. Also check the exhaust mounts on the rear subframe.
michael
PostPosted: Sun Feb 16, 2014 8:41 am
What a wonderful place we have here.
No matter what your drama someone always seems to have a solution.
Brilliant I say
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Feb 16, 2014 10:40 am
Sounds like the exhaust may be the problem, but just to be sure:
You don't get any grinding going into reverse? The answer to 'the engine struggles at idle in x gear' is usually because the clutch is dragging. No synchro on reverse means it will grind. If that's the case, give it a bleed, and if that doesn't fix it look at a new clutch hose and cylinder.
PostPosted: Sun Feb 16, 2014 5:21 pm
Thank you all, it was the starter button shorting out on the exhaust. A simple twist and now all good!
PostPosted: Sun Feb 16, 2014 5:33 pm
Glad you were able to fix it. I made up a bracket for mine to hold the exhaust away from the starter button.
Cheers Pete
Users browsing this forum: fuzzy-hair-man and 112 guests
