What caused this https://www.ausmini.com/forums/viewtopic.php?f=2&t=84628 |
Page 1 of 3 |
Author: | Booglie [ Mon Feb 17, 2014 5:48 pm ] |
Post subject: | What caused this |
Today I was sitting at the lights with my mini idling and it started to miss I wasn't far from home so I drove the next few hundred metres in first gear very slowly, upon getting home I removed the plugs to check them out and was shocked to find number one plug in this state. ![]() ![]() What would cause this to happen at idle? |
Author: | Monaco [ Mon Feb 17, 2014 5:56 pm ] |
Post subject: | Re: What caused this |
Looks like something is floating around in the combustion chamber.....a bit of valve, piston or ring? Looks like the thread has been hit by something too! |
Author: | Booglie [ Mon Feb 17, 2014 6:03 pm ] |
I forgot to mention the engine done this approximately 6 months ago on one and two, upon discovery I removed the head but could not find any object or damage inside the chamber it seems very odd to me, I will be removing the head to check again though. |
Author: | mini_mad_matt [ Mon Feb 17, 2014 6:44 pm ] |
I would also say looks like something has been in there that doesn't compress very easily. |
Author: | norton [ Mon Feb 17, 2014 10:27 pm ] |
something may have been sucked in and then passed through into the exhaust. I had a piece of carby slide break off and do the same to a plug on my bike ! |
Author: | Convertible Mini [ Tue Feb 18, 2014 6:32 am ] |
You could use 'short reach' plugs!!! They lower compression and will also prevent this from happening again. |
Author: | micool [ Tue Feb 18, 2014 8:28 am ] |
Sh*t that don't look to good it may have passed through into the exhaust by now. |
Author: | Diesel27 [ Tue Feb 18, 2014 8:21 pm ] |
It must be of some concern that this same event occurred recently? like norton mentioned, have you any missing pieces from the intake side? Limit valve still in one piece? |
Author: | gtogreen1969 [ Tue Feb 18, 2014 8:45 pm ] |
Its amazing what you find in engines sometimes. I had a hilux that stalled one day. Popped the bonnet and noticed the aircleaner was loose and the centre stud on the carby was missing. Found the stud stuck in number 3 inlet valve. A $50 head gasket and 3 hours later it was running again. |
Author: | 69k1100 [ Tue Feb 18, 2014 9:31 pm ] |
Still have both the screws on the carb butterfly? They're deformed from the factory so they don't come out but if someone's put a normal screw in it could have fallen out and been sucked in. Personally I would pull the head. You'd have to be very lucky for it to have missed the valves on the way through. |
Author: | i got a mini [ Wed Feb 19, 2014 6:10 pm ] |
If u have double valve springs make sure the inner spring isn't broken and losing peices ![]() |
Author: | Diesel27 [ Wed Feb 19, 2014 7:49 pm ] |
that is interesting, can this still happen with single valve springs? |
Author: | Mick [ Wed Feb 19, 2014 7:50 pm ] |
i got a mini wrote: If u have double valve springs make sure the inner spring isn't broken and losing peices ![]() Certainly important when you have coil bind from too great a lift for the springs, but there's not really a path into the intake from the rocker cover. |
Author: | i got a mini [ Wed Feb 19, 2014 8:43 pm ] |
Didn't think of that now lol my bad |
Author: | Monaco [ Thu Feb 20, 2014 10:41 pm ] |
Might pay to borrow a bore scope and have a look in the cylinder? |
Page 1 of 3 | All times are UTC + 10 hours |
