It is currently Wed Jul 30, 2025 12:12 pm
 Post subject: Gearbox ID
PostPosted: Sun Mar 23, 2014 3:21 pm
G'day fellas picked up a couple of gboxes yesterday wandering what they are....
22g1832. 5/3239
22g1128. 30/1979
22g1832. E641
What do these belong too? Cheers
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: Gearbox ID
PostPosted: Sun Mar 23, 2014 3:44 pm
22G1832 is a common Oz Clubby rodchange box, small journal idler gear (ie NOT A+).
22G1128 is a 4 synchro remote box, could be Mini-K, Mk2S, 1098 Clubby, (or 1098 Moke if it has a puddin' stirrer shift on it).
PostPosted: Sun Mar 23, 2014 3:50 pm
Thanks doc. No idea what the other is? I think it is mk 2 s box has the s flanges on it.
1970 mini k
1975 leyland
PostPosted: Sun Mar 23, 2014 3:52 pm
If it has S flanges it may be an S box or been used in one, count the teeth on the 1st motion shaft.
18T = Mk2S or GT gear ratios
17T = common K etc ratios.
or check part number on cluster gear, 22G1040 = Mk2S or GT.
PostPosted: Sun Mar 23, 2014 3:57 pm
Didn't the Moke box have Hardy Spicer outputs too?
PostPosted: Sun Mar 23, 2014 4:55 pm
I dunno, I've never owned one that vintage.
Both mine were 998s with pot joints.
PostPosted: Sun Mar 23, 2014 5:16 pm
Dad's 1100 Moke with 1128 had hardy spicer uni's, 1972 vintage.
PostPosted: Sun Mar 23, 2014 5:35 pm
Remembering that remote boxes are in the region of 40+ years old so anything goes in terms of output shafts/diffs/ even the gearset.
Get a part number or count the teeth.
PostPosted: Sun Mar 23, 2014 5:41 pm
The Mini King
They sure did, You are spot on again Morris 1100
PostPosted: Sun Mar 23, 2014 6:11 pm
This Morris fella , he's like the kid that only shows up for school twice a week , then gets 100% in his school exam :shock: :lol: :wink: .
PostPosted: Sun Mar 23, 2014 8:21 pm
Ok thanks for all ya help fellas. Ill count the teeth and see what I have cheers.
1970 mini k
1975 leyland
PostPosted: Sun Mar 23, 2014 9:08 pm
oh oh pick me pick me.....
I have one and yes they did :lol:
The GT gearbox has a code stamped into the side of the gearbox signifying it has close ratio gears (just cant remember the code). I would assume the Cooper S does also.
PostPosted: Sun Mar 23, 2014 9:34 pm
The Mk1 Cooper S has a number like an engine number stamped on the box, something along the lines of 9Y/1234 (don't make me go out to the shed to look!
The Mk2 has a different code. (but I don't have one here to check!)
The normal cars have a 12345/6 type of number.
These numbers will somehow define what the box was when it left the factory. I will take some photos tomorrow of what I have.
PostPosted: Mon Mar 24, 2014 2:26 pm
so does anyone know what the third box is off? 22g1832. E641..........i counted the teeth on the pinion and theres 18 teeth. the box is really hard to turn over though.
1970 mini k
1975 leyland
PostPosted: Mon Mar 24, 2014 2:50 pm
It's a rodchange box as I said.
18T pinion = a 3.44 diff = Clubby (shaped car) of some sort.
Could be from any of them, really...
Users browsing this forum: Bing [Bot] and 79 guests
