Morris M horn push needed. Any condition
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84673
Author:  geoffminiman [ Thu Feb 20, 2014 7:21 pm ]
Post subject:  Morris M horn push needed. Any condition
Hi guys
I want to make a replica M horn push centre as I see that they are rare in good Nik.
I'm going to make a mould to have a crack at casting a new one.
I need an average one that it won't be tragedy to destroy if I that happens during the mould making process.
Does anyone have an average one that I can have?
I'm happy to offer up the first good replica I can make if I am successful to whoever has one for me?
Author:  Aussie Brian [ Thu Feb 20, 2014 7:39 pm ]
Post subject:  Re: Morris M horn push needed. Any condition
I'm happy to offer up the first good replica I can make if I am successful to whoever has one for :shock: me?
:shock: :shock: yep here's one
http://www.ebay.com.au/itm/171239157551 ... 1438.l2649
Author:  GB1275 [ Thu Feb 20, 2014 7:54 pm ]
I don't have one though here's one on ebay finishing shortly:
http://www.ebay.com.au/itm/221371855530?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_25wt_1362
If you're making some I'd be interested in buying one from you to use for the centre of a Moto-lita sterring wheel...their standard "Mini" hub logo looks pretty lame IMHO.
Author:  drjbeam [ Thu Feb 20, 2014 10:03 pm ]
Mini moke world should have one at brookvale there the closet to you if not pm mini king on here
http://www.miniandmokeworld.com.au/webs ... oryID=1217
Author:  timmy201 [ Fri Feb 21, 2014 6:30 am ]
I've got one with a chip on the edge. Is that any good for your mould? I don't need it..
Author:  geoffminiman [ Fri Feb 21, 2014 11:56 am ]
sweet. PM sent
Author:  69k1100 [ Sat Feb 22, 2014 3:07 pm ]
The problem you will have is the silver coating. Casting it isn't a problem, I am working on the k bonnet badge ATM.
The silver coating to my knowledge is deposited through vacuum metalising, if you have a vacuum pump you can have a crack at this process yourself (you should invest in one to degas the resin anyway.
Also don't use polyester resin as the surface doesn't cure when in contact with air. Polyurethane Should work, just consult someone who works with this every day.
