It is in and on now. The tricky bit is the spring behind. If your not careful it will pop off and hence not seal the lip. How i did it. I placed the primary gear thrust washer onto the crank and applied a little oil to hold it in place. Then once i had the primary gear seal seated into the clutch housing i placed the primary gear into it and then made sure the lip was correct and not folded over. Doing this whilst havng the housing off the engine allowed me to make sure it was correct on the back side and that the spring was in place . Happy! I then assembled it all on the shaft making sure not to dislodge the thrust washer. You know when you have as you can't get the primary gear on the shaft far enough to get the circlip and washer into place. Do it all up and bob's my uncle! Happiness is a Built motor. Well almost. Just have to put the clutch in and a head on. Then it looks like a motor. I will then put on some ancillaries and start it on the floor. Best to know if you have made a mistake before putting it into the enigne bay..... I have lernt that lesson.
JAM if Doc put your seal in, you should be right, i am sure he's done a few in his time.
Mickmini, i asked the question as i had a seal go awry before, wasn't confident, but now that i have the thing sitting in right and not all busted up. all will be well.
Aaron
