It is currently Mon Jul 28, 2025 9:38 am
PostPosted: Sun Mar 02, 2014 9:17 am
I'm getting together all the bits for my 1969 mini for rechroming, do I need to remove the lock from the drivers side door handle before it can be rechromed?
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sun Mar 02, 2014 9:27 am
Yes it makes easier when they do the finishing polish
PostPosted: Sun Mar 02, 2014 9:32 am
Thanks, how do you get the locks out?
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sun Mar 02, 2014 8:31 pm
Have you looked at the "how to" section?
viewtopic.php?f=25&t=69906
viewtopic.php?f=25&t=60640
PostPosted: Sun Mar 02, 2014 10:30 pm
Thanks for the links. They will come in handy when reassembling the doors. But the links don't describe how to remove the lock barrel from the drivers side door handle of early wind up window doors.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Mon Mar 03, 2014 6:36 am
There is a pin in there, punch it out, note the lock must be in the `unlocked' position to remove it.
PostPosted: Mon Mar 03, 2014 7:48 am
Thanks, I'll have another go at it this week. I'll post photos if I'm successful.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Mar 08, 2014 9:08 pm
Ok, I have managed to get the lock pin out. How do you get the lock plunger out to separate the handle from the escutcheon?
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Tue Mar 11, 2014 8:36 am
It should pull out with the key, in the unlocked position.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Mar 11, 2014 4:45 pm
The Mini King
There can be a total of 3 Pins, Or 2 pins and a split Pin
The split Pin Holds the escutcheon to the handle, This sometimes
can be a pin, 2 this Pin holds the square steel section to the Die cast handle,
There is no need to remove this, the third pin a small brass pin holds
the barrel in the Handle, Once You have removed this Pin Spray some WD40
or something similar around the barrel section, Then as previously said,
use Your key to pull the barrel out, Sometimes You may have to tap the handle
on a hard surface like a piece of wood with some cloth covering the wood
Note do not have Your handle Plated with the barrel in place, no matter what anyone says
PostPosted: Tue Mar 11, 2014 10:04 pm
Thanks Tim and John. I've got the barrel out, it looks like just the lock plunger (square piece of metal the lock moves to stop the handle turning in the escutcheon ) is stopping the handle from being removed from the escutcheon. I'll have another go tomorrow night and take a photo.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Wed Mar 12, 2014 11:13 am
Err, sorry, its been a while, I thought it came out sideways after you pull the barrel out, but you'd have to move escutcheon down to get to it.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Wed Mar 12, 2014 12:00 pm
The Mini King
What Tim is telling You is spot on, Move the square metal section
so that it is the middle not poking out either side then move the escutcheon down
then slide the square metal piece out altogether.
PostPosted: Wed Mar 12, 2014 12:22 pm
That's it I remember now.
John, how do they come up after rechroming? Is the alloy that they are made out of usually OK, or does it end up with pits in it?
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Wed Mar 12, 2014 1:27 pm
The Mini King
Tim,
It is one of the worst metals to Re Chrome, It depends on the plater and the customer
How good they come up, The plater will have to put a lot of time into polishing it before
plating, He can only go so far with the polishing process, and if it is still pitted then he will have to put
a very thick coat of copper on it, This hopefully will give him enough depth so that he can try polishing
the copper Smooth, if this does not work he will have to put another coat of copper and polish it again
once it is smooth he will then put a good coat of Nickel and then Chrome Plate,
Why I say it depends on the Plater and the customer is
It depends on the plater if he willing to spend the time if he has to plate then polish then plate again
It depend on the customer if he is willing to pay for so many processes
this is why You will often see pits in re plated die cast, also there are some areas that cannot be polished
well enough To remove the pits
With modern Plating solutions it is sometimes possible to put one very thick coat of copper,
because the Plating solutions have better levelling properties than they did years ago,
But it is still an expensive process
